I want connect Thingworx studio with Thingworx Foundation
CHASEONHO
18-Opal
Hi
last weekend i was start Thingworx studio trial
and i want connect studio to composer
so get Thingworx foundation's thing value send to studio
if you know how to connect studio and composer
teach me how to connect it
Hi seonho Cha​,
ThingWorx Studio Trial version has ThingWorx Experience Server and ThingWorx hosted by PTC. And they are already connected.
Their is no direct way to connect local PTC with ThingWorx Studio.
you can consider connecting ThingWorx (for Experience server) with your local ThingWorx.
Configuring the federation between your local Thingworx and (ES) ThingWorx platform should be one of the possible workaround.
I hope it helps.
6 REPLIES 6
AnnaAn
(To:CHASEONHO)
Dear seonho Cha​,
Could you have a look of this material to see if it has any help?
Studio - Using Reading Property from Thing Worx - YouTube
Br,
Anna
Thank your reply Anna An
i using Thingworx Composer in server
and i want connect server Thingworx to local studio
(Thingworx studio local:3030/home and it's Thingworx Composer local:3030/Thingworx)
I think Thingworx Composer connect Thingworx Studio hasn't work
but trial Thingworx Composer connect Thingworx Studio
I'll keep find a way about connect Thingworx studio with Thingworx Composer that wasn't trial Composer
AnnaAn
(To:CHASEONHO)
seonho Cha​,
You may also need take a look at :
Studio - Using ThingWorx Introduction - YouTube
Br,
Anna
Hi seonho Cha​,
I hope it helps.
Hi Ankit Gupta i have one doubt is there any problem with the PTC thingworx and Mqtt seems that my mqtt on local system works fine but with Thingwortx experience server it is not connecting can you check.
Thanks Ankit Gupta
Thanks Anna An
