I am working on project where AR and IOT integration is done in vuforia studio.
In preview mode i can see the real time IOT data from shop floor machines. But once i m viewing experience through I pad label widgets which got binded from thingworx IOT data are not showing any data.
has anyone faced this? how to resolve this.
the image of preview mode is attached here, but i want to see the same data on ipad .
Have you checked the permissions on your thing, if you are using public (no password) the es-public-access user must have access to the properties.
/Per
/Per
thanks for immediate reply.
actually it was issue of authentication of user which is solved .
Earlier there was a similar question - "How can I able to view my experience in Iphone which supports AR kit": https://community.ptc.com/t5/Vuforia-Studio/How-can-I-able-to-view-my-experience-in-Iphone-which-supports-AR/td-p/530803
