Hi there,
It used to work fine to preview Section created in Illustrate Sequence with Vuforia Studio.
But not it's broken, still visible on devices.
How to fix it?
Thanks in advance.
Hi @dsgnrClarK ,
is this secion shown in the picture created by the sectioning tool in Creo Illustrate?
What are the versions of the used Illustrate and Studio?
So far I know, still section cuts are not supported yet. But I am not 100% sure , may be in the mean time I missed some announcement (need to check what’s new more carefully )
Therefore, I checked it with Creo Illustrate 6.0.0 and Vuforia Studio 8.5.5
But I was not able to see the section/s created with sectioning tool in Creo Illustrate - also the section was not visible also in preview mode:
Did you have some specific non default setting in Studio?
Otherwise I want to referrer to possible workarounds discussed in following posts (one we discuss regarding similar issue in the past) :
How to accomplish real-time Sectioning function like this?
and
Hi @RolandRaytchev ,
Thanks for reply.
Yes, I created the section by the sectioning tool in Creo Illustrate.
I'm using Illustrate 6.0.0 and Vuforia Studio 8.5.5 as well.
With default settings.
By the way, the Still Section I created is in a static Figure, no Sequence/Animation in it.
Have you tried publishing the experience and open it with Vuforia View on mobile device?
It works.
Even it is not visible in Preview mode.
Hi @dsgnrClarK ,
thanks for clarification, I will check now on mobile devices /android and IOS and HoloLens /not today but hope this week/
And well discuss it with dev team. May be there are some changes...
