Hi, all
I tried to publish using Image target.
I just added Image target and 3d model.
and then I did published.
but publishing was faid with below log message.
"message": "{\"message\":\"An error occurred while generating targets\",\"errorCode\":\"\",\"error\":{}}"
why I failed the publish?
how can I fix it?
Hi @jsj ,
so following points to clarify:
- experience service is it PTC cloud or is on premises server (in house local installed server)?
- what is the version of your experience service ? <YourServerURL>\ExperienceService\properties or<YourServerURL:port>\ExperienceService\properties
If you use Experience server on Centos or Ubuntu and it is a local server installed on local environment then it is possibly that on your server
Hi @jsj ,
Hi, RolandRaytchev
after installing the mesa-libglapi package on ES, I checked that I can publish image target.
Thanks for your answer.
