Imported .DGN (Microstation) does not vae viewable
mneufeld
I am trying to import a .dgn file (Microstation), import is very quick, .pvz is created (but inside does not have any viewable .ol files, only one .pvs file) but when I assign it to model - there is nothing in the scene, nothing displays.
Exported .dgn comes from this software and according to vendor it's version (v8) is on Supported CAD for Vuforia Studio:
Bentley MicroStation DGN
The following table lists the MicroStation DGN file versions that ArcGIS Pro supports:.
Software
Format version
Direct read
Exported
MicroStation 95
5
Yes
V8
MicroStation SE
5
Yes
V8
MicroStation/J
7
Yes
V8
MicroStation V8
8
Yes
V8
Microstation V8i
8
Yes
V8
Microstation Connect Edition V10
10
Yes
V8
I also tried Vuforia Studio logs - no errors/warning during file conversion. I went to cmd line converter dgn2pv, turned on all verbose, nothing bad in logs.
I attach .dgn file. (it is zipped, so pls extract archive before importing)
Any hint would be appreciated.
sdidier
(To:mneufeld)
Hello mneufeld,
I have used Bentley Viewer to be able to see something.
It is available at this URL :
https://www.bentley.com/fr/products/product-line/modeling-and-visualization-software/bentley-dgn-reader-for-windows
I have this result in Windows Explorer :
It seems a Drawing because when rotating, everything is in a plane.
In Vuforia Studio, I am able to reproduce the same behavior has described.
In .pvz file generated by Vuforia Studio, we can only find a .pvs file who is very short.
No .ol files who contains 3D geometry.
  • Do you want to import in Vuforia Studio this model or to do you expect a 3D model ?
Best regards,
Samuel
