Hello, I have a problem while connecting to my account to configure Vuforia Studio I have an eroor "Application not found", the description of the of the error.
PS: I tried to uninstall and install again but it doesn't work.
System.ComponentModel.Win32Exception (0x80004005): Application introuvable
à System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
à System.Diagnostics.Process.Start()
à System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
à com.ptc.ThingworxStudio.MobileBuilderForm.btnLogs_Click(Object sender, EventArgs e)
à System.Windows.Forms.Control.OnClick(EventArgs e)
à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
à System.Windows.Forms.Control.WndProc(Message& m)
à System.Windows.Forms.Label.WndProc(Message& m)
à System.Windows.Forms.LinkLabel.WndProc(Message& msg)
à System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Hello @sdidier, I found where the problem comes from, it is because my cnnexion was bocked so i just installed VFS in another computer connected to another network and all work properly.
Thank you for your time,
Thomas
Best regards,
Samuel
Hello @sdidier, thank you for your answer.
I guess Vuforia Studio is not installed in the correct folder ?
Best regards,
Thomas
If Vuforia Studio is not in this folder %USERPROFILE%\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io where is located in your computer ?
Best regards,
Samuel
Hello @sdidier,
It is in this foler : %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\PTC Inc
Best regards,
Thomas
Hello TB,
To be honest, it is very strange!
Vuforia Studio installer is installing Vuforia Studio in same folders for everyone.
By the way, the .exe Application location can be found by using Task Manager.
This path has this format : %USERPROFILE%\AppData\Local\Apps\2.0\<RANDOM NUMBER>\<RANDOM NUMBER>\vufo..udio_<RANDOM NUMBER>
It is the folder where we can find application itself.
For example, in my workstation, we have :
Best regards,
Samuel
Hello @sdidier,
Yes i made a mistake i have the same things as you in the 3 differents folders. I have this in my workstation
The size of the folder is 375 Mo.
Best regards,
Thomas
Hello Thomas,
No problem!
It is just to be accurate because we share this knowledge to everyone on PTC community. 😊
Please follow these steps :
1. Shutdown Vuforia Studio:
a. In Windows task bar, click the ^ icon to expand it
b. In this frame, found Vuforia Studio icon
c. Right click on it
d. In popup menu, click Quit menu
2. Check if Vuforia Studio is already shutdown correctly
a. In Windows Task Manager, in Processes tab, find processes named Vuforia Studio (32 bit) and Node.js: Server-side JavaScript
3. In one of the vu..udio_<random number> folder, a Studio.exe can be found
4. Run this application
For step 1, I suppose icon is not present.
For step 2, I suppose also that these processes are not present. Be carreful, if Vuforia Experience Service is installed on this Windows computer, a Node.js: Server-side JavaScript process should be present also for this product.
Thanks in advance for your feedback.
Best regards,
Samuel
Hello @sdidier,
After shutting down Vuforia Studio I cant find Vuforia Studio (32 bit) and Node.js: Server-side JavaScript. I checked what I have when I run Vuforia Studio and I do have the two processes.
I runned the Studio.exe present in one of the folders but i still have errors :
I dont have anythings in the studio.log file :
Thank you for your answer,
Thomas
Hello Thomas,
Thanks you for your feedback.
I have some more questions :
Thanks in advance for your help.
Best regards,
Samuel
Hello @sdidier,
Thank you for your answer.
Thank you for your help
Best regards,
Thomas
Hello Thomas,
Best regards,
Samuel
Hello Thomas,
I would suggest to look in quarantine area defined in McAfee.
Please have a look to these web pages in McAfee web site :
Best regards,
Samuel
Hello @sdidier,
Thank you for your help, i've read what you send me and checked the quarantined section of McAfee on my computer but there is not Visual Studio or anythings linked to it in so I deduce from that McAfee is not interfering on Visual Studio.
Best regards,
Thomas
Hello Thomas,
I have reported this issue to R&D in Jira Ticket VTS-204.
I would open a case to follow that.
Best regards,
Samuel
Hello Thomas,
I have some questions :
Best regards,
Samuel
Hello @sdidier ,
Best regards,
Thomas
Hello Thomas,
It has a size of 77kb in the screenshot.
Best regards,
Samuel
Thomas
Hello Thomas;
It is a good news.
Best regards,
Samuel
