Is it possible to change the port number for ThingWorx Studio?
sully7
Hello ThingWorx community!
I  just installed the ThingWorx Studio (v1.11), and had a quick question. From what I can tell, ThingWorx Studio sets up a local virtual environment, which then opens the "portal" located through localhost:3000.
We have other applications that use that directory, and it is causing a conflict... so I was wondering - Is there a way to change that port number to something else? I've poked around briefly, and thought maybe there would be a setting located inside of my "ThingWorx Studio.exe.config" file, but have not found any way to easily change it.
James
President & Founder
CadActive Technologies - www.cadactive.com
Hi James,
for changing the port, set a Environment Variable (System Variable) under System Properties called ​PORT​ and point it to any port number you want to use. After starting Studio, you will need to manually address the new port in the browser's URL, as the "Open" button is hardcoded to port 3000 - so e.g. to http://localhost:<newPort>
Same manual port change goes for the Preview tab, as it opens with port 3000 as well.
R&D also already created an enhancement for this to get it configurable more easily and more integrated in a future version of ThingWorx Studio.
I hope that helps...
Cheers,
Michael
Hi James,
I had a look at the basic configuration files but could not find a setting to change the port - but let me look into it a bit closer before I give a final answer.
Cheers,
Michael
Hi James,
Cheers,
Michael
sully7
(To:mneumann)
Awesome!! Thanks for looking in to this.
President & Founder
