Is possible to configure the Experience server with Thingworx Docker
afherrerac
6-Contributor
Good morning, i have a question if is possible to connect vuforia experience server with thingworx in docker also if exist any way to use vuforia studio in linux
Good morning Afherrerac,
To connect Vuforia Experience Service to a ThingWorx in a docker.
Until ThingWorx is exposed, it might works.
From Vuforia Experience Service, ThingWorx on a docker or installed as a standalone server, it should be the same.
No difference in the setup of Vuforia Experience Service.
To use Vuforia Studio on Linux, it doesn't exist a Linux package provided by PTC.
So, the only solution but who is not supported is to use Wine (as any other Windows application).
It might work as it might not working.
More details about Wine :
https://www.winehq.org/
Best regards,
Samuel
afherrerac
6-Contributor
(To:sdidier)
Yes, it was helpfull Do you know if is possible to create a Vuforia Studio Container with the purpose to use it in Linux environment?
