I would like to build a sample application where I can tell people or customers to just download the View app and scan the ThinkMark. The application I programmed should also start directly on it.
So far I always have to scan the QR code from the Experience Service before I can access my ThinkMarks. Is it possible to avoid this?
Hi @JS_9007819 ,
it depends on it how you did configure you experience.
You can set in the experience project to have direct Thingmark association.
In this case you can simple start Vuforia View and it will go to scan mode where you can scan the Thingmark. Then it will open the start View / e.g. default is Home. If the start view /e.g. Home / has a Thingmark target widget which point to the same thingmark ( e.g. 15614:40 ) as specified in the Experiences section - in this case it will use this thingmark / scanned on start / Means the same thingmark is used also for the setting of the position of all widgets on this view. With other words there is no second scan required.
To work this, you need
Hi @JS_9007819 ,
