The scenario is that we are thinking to get the 3d models from windchill to thingworx and then to vuforia studio.
What can be the best scenario?
1) Integration of thingworx with windchill (any documentation)
Or
2) We upload the 3d models in thingworx repositry and fetch them in vuforia studio? if possible is there more information about the process?
Hi @Jamal8548 ,
for the point 1.) data migration from Windchill to Thingworx repository , please, contact the Windchill Customization Visualisation group/ believe configuration the worker to export data which could be imported later - or /possibly the bether option/ you can check the Thingworx naviage so you can post your quesiton in the Thingworx developement communty - Thingworx Navigate communty https://community.ptc.com/t5/ThingWorx-Navigate/bd-p/thingworxnavigate . So far I have informaiton from the Navigate team there are some kind of connectors which coould be customized to different tasks and possibly this could be hepful for you to manage this task. Please, address the quesiton 1.) there . Thanks
to point 2) - let say you have all data already uploaded to a folder into a think which is created from FileRepository template. In this case you can use the LoadBinary service to start downlaod and then to received the model in the LoadBinary-complete event some think like that:
//---loading the model
$scope.app.LoadModel = function(widgetName,path ) {
console.warn("$scope.app.LoadModel(",widgetName,",src,",path,")")
$scope.wdgName=widgetName
$scope.serviceName='LoadBinary'
$scope.repositoryThing='CADRepository1_test'
var parameters = {"path":path} ; console.warn(parameters)
twx.app.fn.triggerDataService($scope.repositoryThing,$scope.serviceName,JSON.parse(JSON.stringify( parameters)));
$scope.$applyAsync();
console.log("after callLoadBinaryContent wdgName:"+$scope.wdgName)
//========== the LoadBinary-complete event
$scope.$root.$on('LoadBinary-complete', function(event, args) {
console.log("LoadBinary-complete event");console.log("name="+event.name)
console.warn(args.data[0].Content)
$timeout((data)=>{
$scope.setWidgetProp( $scope.wdgName,'src',data );
},500,true, args.data[0].Content)
So in the example it will set the received data to the src of a model widgit (name of the widgit is in the variable $scope.wdgName. So to work that you need to add the Thingrepository to the external data /here CADRepository1_test and the service LoadBinary
Also all data and services which should be accessed in Vuforia Studio should be conigured according the Studio help:
https://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2FAnonymousAccess.html%23
https://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2FGrantUserPermissions.html
Thank you @RolandRaytchev for always supporting the community. you are passing data in the timeout function but the data itself is deriving from args. can you please see now i am taking the data and i mean content below and assigning it to model.
let a =args.data[0].Content
$timeout((a)=>{
console.log("yes",a);
$scope.setWidgetProp( $scope.wdgName,'src',a );
service response below
error for now
this is pvz file which i am taking from thingworx repositry and setting it to the model.
Hi @Jamal8548 ,
so far it should work but it seems that it has an issue to get the whole data at one piece ... not sure, at all. The data is printing OK and I remember that was working in the past.
So possibly with small pvz that will work , e.g. some cube pvz with small size to see if that issue is still there.
I looked in some of my projects and see that I was also faced with this issue in the one of the 9.15+ version and used a different approuch which was working on mobile... some code like that:
// Event : LoadBinary-complete
const dataURI= ('data:image/pvz;base64,'+args.data[0].Content).replace(/\n/g, '').trim();
const blob = dataURItoBlob(dataURI);//---- //possibly this blob get the whole object from server and not only part of it!!!
//because otherwise it does not make any sense but without this it did not work at all
console.warn("blob = ");console.warn(blob)
const objectURL = URL.createObjectURL(blob);
$scope.setWidgetProp( 'textArea-1','text',JSON.stringify(objectURL).slice(0,100) );
//https://developer.mozilla.org/en-US/docs/Web/API/HTMLMediaElement/srcObject
$timeout((data)=>{
//$scope.setWidgetProp( $scope.wdgName,'scale',$scope.app.curr_scale );
$scope.app.params.scale=$scope.app.curr_scale
for(let i=0; i<11;i++) $timeout(()=>{$scope.$applyAsync(); },50*i);
},500,true,'data:image/pvz;base64,'+ args.data[0].Content)
$scope.app.LadeModelTest=()=>{
console.log("only print for the LadeModelTest to see that it was called");
//$scope.app.LadeModel('model-1','/CAD/Engine_Low.pvz')
// $scope.app.LadeModel('model-1','/pvz/mill5MT_High.pvz')
$scope.app.LadeModel('model-1',$scope.app.randomMod())
code is not really a good programming style example ... but tested in the 9.21 with project and it worked - tested now in preview - is ok. So far I see your issue is in preview - so frist there to check. I will attach a demo project
To get the project working without many changes you need to have a repostitory thing with the name
const TWXmodelID = 'CADRepository1_test'
or you have to change the code line 6 on Home.js to the name of the repository what you use
Also you have to load some files into a folder of your repository . Add that information in the Lines 37-45
$scope.app.ListeMods=[
{'name':'3dgauge1','pvz':'/pvz/3dgauge1.pvz','scale':3},
{'name':'bla-bla','pvz':'/pvz/bla-bla.pvz','scale':3},
{'name':'engine_test_exp','pvz':'/pvz/engine_test_exp.pvz','scale':0.5},
{'name':'mill5MT_High','pvz':'/pvz/mill5MT_High.pvz','scale':1},
{'name':'navipad','pvz':'/pvz/navipad.pvz','scale':2},
{'name':'ventil_bg_anno','pvz':'/pvz/ventil_bg_anno.pvz','scale':3},
{'name':'wandregal','pvz':'/pvz/wandregal.pvz','scale':0.5}
here you should provide information abouth the name, pvz filename and Studio display scale... so means you can change that informaiton according to the used repository folder and data what is loaded there.
Also you need to add LoadBinary into the external data section / so first remove the old objects and recreate the bindings again
Also,please, take care that LoadBinary service has the correct permission in TWX but I think that is something what you alreay set ... so regarding the status of the provided pictures
I hope that helps! If not then, please , let me know. Thanks
so the code of dataURItoBlog() function mention in the post... also in the project
// function deffintions
function dataURItoBlob(dataURI)
// convert base64/URLEncoded data component to raw binary data held in a string
var byteString;
if(dataURI.split(',')[0].indexOf('base64') >= 0)
byteString = atob(dataURI.split(',')[1]);
else
byteString = unescape(dataURI.split(',')[1]);
// separate out the mime component
var mimeString = dataURI.split(',')[0].split(':')[1].split(';')[0];
// write the bytes of the string to a typed array
var ia = new Uint8Array(byteString.length);
for(var i = 0; i < byteString.length; i++)
ia[i] = byteString.charCodeAt(i);
return new Blob([ia], {type: mimeString}); //'video/ogg'
so took it from so some post of the Stack Overflow but could not rember ...
Hi @RolandRaytchev , I am able to get the model from thingworx repository. Below is my code and it loads the model(pvz file) from repository but now question is that there is only one sequence in this model which is called Abbilding 1 and i want to set the sequence also but i am unable to set it.
Its shows in console --> model-1 failed to load pvi Abbildung 1
$scope.wdgName="model-1"
$scope.repositoryThing='V2.FileRepository'
var parameters = {"path":"ML1/0011/1715682357732/1/30122501_animation_matritze.pvz"}
let converted_file= 'data:image/pvz;base64,'+args.data[0].Content
console.warn(converted_file)
$scope.setWidgetProp('model-1','src',converted_file); $scope.$applyAsync();
$rootScope.$on('modelLoaded', function() {
$scope.view.wdg['model-1']['sequence'] = 'Abbildung 1';
any idea about it?
The solution to this issue is to assign full name to sequence and then it works. In the sequences i have the name Abbildung 1 but if you want to assign it in Js style then you need this below statement.
$scope.view.wdg['model-1']['sequence'] = 'l-Creo 3D - Abbildung 1.pvi';
i will do now further testings.
Hello @Jamal8548,
It looks like you have some responses on your topic. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
I still need some time for proper testing. i will be back on this topic in upcoming weeks. Thanks.
