Isolate model item (not working in last vuforia studio version)
GianVal
What is the best way to isolate the visibility of a model item, that is to make only a selected item visible via a button?
I have successfully used a combination of
tml3dRenderer.setProperties(modelitem, {hidden: true})
but the latest update seems to have broken this mechanism.
It does not work anymore. so I'm wondering what is the best way to select a component and then isolate it from the others.
Thank you
please note that I'm NOT using model items in Vuforia Studio, I only use metadata.json to retrieve the model parts.
Tested the code in the latest Studio Version Version 9.3.2 (9.3.2.5397) preview mode and IOS IPad - was working fine. Attached the test project. Relevant code
 isPreview = function() {
    if(window.twx.app.isPreview()) // is in Preview
         return true;
   return false; }
function hide3DObject(name) {
  if( isPreview())
    tml3dRenderer.GetObject(name).GetWidget().SetVisibility(false);
  else
    tml3dRenderer.setProperties(name,{ hidden:true} );
  $scope.$applyAsync();
function show3DObject(name) {
    if( isPreview())
    tml3dRenderer.GetObject(name).GetWidget().SetVisibility(true);
    else
    tml3dRenderer.setProperties(name,{ hidden:false} );
$scope.setShow= function() {
console.warn("setShow()");
show3DObject('model-1-/0/0/3/2');
show3DObject('model-1-/0/0/9/4/1');
show3DObject('model-1-/0/0/4/1');
show3DObject('model-1-/0/0/1/7/1');
show3DObject('model-1-/0/0/1/4/65/3');
show3DObject('model-1-/0/0/1/1/1');
show3DObject('model-1-/0/0/4/4');
show3DObject('model-1-/0/0/1/1/18');
show3DObject('model-1-/0/0/1/9/1');
show3DObject('model-1-/0/0/10/2');
$scope.setHide= function() {
console.warn("setHide()");
hide3DObject('model-1-/0/0/3/2');
hide3DObject('model-1-/0/0/9/4/1');
hide3DObject('model-1-/0/0/4/1');
hide3DObject('model-1-/0/0/1/7/1');
hide3DObject('model-1-/0/0/1/4/65/3');
hide3DObject('model-1-/0/0/1/1/1');
hide3DObject('model-1-/0/0/4/4');
hide3DObject('model-1-/0/0/1/1/18');
hide3DObject('model-1-/0/0/1/9/1');
hide3DObject('model-1-/0/0/10/2');
then in preview
simple demo project attached - mobile  ShowHideCommunityExample.zip 2,580 KB
Hi @GianVal ,
could you provide simple sample project where this not work. I did test in the  latest version some code like this below , but it was working fine:
         return true;
   return false; }
  if( isPreview())
  else
    if( isPreview())
    else
show3DObject('model-1-/0/3/1'); //show the comp with path /0/3/1 for model widget model-1
show3DObject('model-1-/0/3/2'); //show the comp with path /0/3/2 for model widget model-1
hide3DObject('model-1-/0/3/3'); //hide the comp with path /0/3/3 for model widget model-1
I started a new experience from scratch, just importing a pvz. executing your code (customizing the model item referencies of course) I get this error
TypeError: Cannot read properties of undefined (reading 'SetVisibility')
    at show3DObject (app.js:263:50)
         return true;
   return false; }
  if( isPreview())
  else
    if( isPreview())
    else
then in preview
