I have used the trial version of vuforia and the trial period is over so cannot process further. as a freelancer, I am developing a use case that can be demonstrated to product-based companies. how to get extended the trial period or buy a license. find below the recent article, which is about to circulate to connections but when vuforia is not working then I cannot proceed.
https://www.linkedin.com/posts/karthik20_mbe-modelbaseddesign-mbse-activity-6714203056201969665-1Vzg
Kind Regards,
Karthikeyan Ganesan
Hi @krthk86g
You should be able to request an extension through your dashboard found on https://trial.studio.vuforia.com/. You can also fill out this form: https://trial.studio.vuforia.com/buy/ to get in contact with a sales rep for purchase.
I have requested the extension. I can afford the license cost when I get an active cost.
Kind Regards,
Karthik
