Log in Thingworx Studio
asaito-3
7-Bedrock
Hi All,
I am trying to use the 90-day trial verion of thingworx studio but with no sucess because of  the following error...
Hi Anselmo, Can you try reinstalling Studio? Do you have any other node.js installs on this machine?
dupatel
(To:asaito-3)
Anselmo Saito​: Delete the files under <user home>\AppData\Local\Apps\2.0\ and re-install the studio exe file.The AppData directory is an hidden directory, make sure to enable 'view hidden files' windows configuration.
Also, make sure you do not have an external Nodejs installed as there has been known issue and conflicts reported earlier.
-Durgesh
I deleted Nodejs, I mean, I removed every single thing of its components.
Reinstalled the thingworx studio, but now I am getting a new error in my log...
[12/18/2017 09:18:29] Starting node.exe
[12/18/2017 09:18:31] error: [twx-studio:index] uncaughtException { Error: Cannot find module './../utils/twxml-converter'
[12/18/2017 09:18:31]     at Function.Module._resolveFilename (module.js:527:15)
[12/18/2017 09:18:31]     at Function.Module._load (module.js:476:23)
[12/18/2017 09:18:31]     at Module.require (module.js:568:17)
[12/18/2017 09:18:31]     at require (internal/module.js:11:18)
[12/18/2017 09:18:31]     at Object.<anonymous> (C:\Users\asaito\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\dist\server\routes\sockets.js:14:22)
[12/18/2017 09:18:31]     at Module._compile (module.js:624:30)
[12/18/2017 09:18:31]     at Object.Module._extensions..js (module.js:635:10)
[12/18/2017 09:18:31]     at Module.load (module.js:545:32)
[12/18/2017 09:18:31]     at tryModuleLoad (module.js:508:12)
[12/18/2017 09:18:31]     at Function.Module._load (module.js:500:3) code: 'MODULE_NOT_FOUND' }
[12/19/2017 09:26:38] Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
[12/19/2017 13:08:02] Studio Version 8.1.2 (8.1.2.2343)
[12/19/2017 13:08:02] Status Message: Version 8.1.2 (8.1.2.2343)
[12/19/2017 13:08:03] Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
[12/19/2017 13:08:17] Starting node.exe
[12/19/2017 13:08:30] error: [twx-studio:index] uncaughtException { Error: Cannot find module './../utils/twxml-converter'
[12/19/2017 13:08:30]     at Function.Module._resolveFilename (module.js:527:15)
[12/19/2017 13:08:30]     at Function.Module._load (module.js:476:23)
[12/19/2017 13:08:30]     at Module.require (module.js:568:17)
[12/19/2017 13:08:30]     at require (internal/module.js:11:18)
[12/19/2017 13:08:30]     at Object.<anonymous> (C:\Users\asaito\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\dist\server\routes\sockets.js:14:22)
[12/19/2017 13:08:30]     at Module._compile (module.js:624:30)
[12/19/2017 13:08:30]     at Object.Module._extensions..js (module.js:635:10)
[12/19/2017 13:08:30]     at Module.load (module.js:545:32)
[12/19/2017 13:08:30]     at tryModuleLoad (module.js:508:12)
[12/19/2017 13:08:30]     at Function.Module._load (module.js:500:3) code: 'MODULE_NOT_FOUND' }
[12/20/2017 10:03:33] Studio Version 8.1.2 (8.1.2.2343)
[12/20/2017 10:03:33] Status Message: Version 8.1.2 (8.1.2.2343)
[12/20/2017 10:03:33] Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
[12/20/2017 10:03:36] Starting node.exe
[12/20/2017 10:03:39] error: [twx-studio:index] uncaughtException { Error: Cannot find module './../utils/twxml-converter'
[12/20/2017 10:03:39]     at Function.Module._resolveFilename (module.js:527:15)
[12/20/2017 10:03:39]     at Function.Module._load (module.js:476:23)
[12/20/2017 10:03:39]     at Module.require (module.js:568:17)
[12/20/2017 10:03:39]     at require (internal/module.js:11:18)
[12/20/2017 10:03:39]     at Object.<anonymous> (C:\Users\asaito\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\dist\server\routes\sockets.js:14:22)
[12/20/2017 10:03:39]     at Module._compile (module.js:624:30)
[12/20/2017 10:03:39]     at Object.Module._extensions..js (module.js:635:10)
[12/20/2017 10:03:39]     at Module.load (module.js:545:32)
[12/20/2017 10:03:39]     at tryModuleLoad (module.js:508:12)
[12/20/2017 10:03:39]     at Function.Module._load (module.js:500:3) code: 'MODULE_NOT_FOUND' }
[12/21/2017 09:28:00] Studio Version 8.1.2 (8.1.2.2343)
[12/21/2017 09:28:00] Status Message: Version 8.1.2 (8.1.2.2343)
[12/21/2017 09:28:00] Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
[12/21/2017 09:28:02] Status Message: Performing First Time Setup (Application)...
[12/21/2017 09:28:02] Removing C:\Users\asaito\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\dist
[12/21/2017 09:28:03] Unzipping mbdist.zip to C:\Users\asaito\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\
[12/21/2017 09:28:06] Status Message: Performing First Time Setup (Libraries)...
[12/21/2017 09:28:06] Removing C:\Users\asaito\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\node_modules
[12/21/2017 09:28:29] Unzipping mbmodules.zip to C:\Users\asaito\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\
[12/21/2017 14:50:02] Studio Version 8.1.2 (8.1.2.2343)
[12/21/2017 14:50:02] Status Message: Version 8.1.2 (8.1.2.2343)
[12/21/2017 14:50:03] Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
[12/21/2017 14:50:16] Starting node.exe
[12/21/2017 14:50:45] module.js:529
[12/21/2017 14:50:45]     throw err;
[12/21/2017 14:50:45]     ^
[12/21/2017 14:50:45] Error: Cannot find module 'fs-extra'
[12/21/2017 14:50:45]     at Function.Module._resolveFilename (module.js:527:15)
[12/21/2017 14:50:45]     at Function.Module._load (module.js:476:23)
[12/21/2017 14:50:45]     at Module.require (module.js:568:17)
[12/21/2017 14:50:45]     at require (internal/module.js:11:18)
[12/21/2017 14:50:45]     at Object.<anonymous> (C:\Users\asaito\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\dist\server\utils\logging.js:16:12)
[12/21/2017 14:50:45]     at Module._compile (module.js:624:30)
[12/21/2017 14:50:45]     at Object.Module._extensions..js (module.js:635:10)
[12/21/2017 14:50:45]     at Module.load (module.js:545:32)
[12/21/2017 14:50:45]     at tryModuleLoad (module.js:508:12)
[12/21/2017 14:50:45]     at Function.Module._load (module.js:500:3)
[12/21/2017 15:39:50] Studio Version 8.1.2 (8.1.2.2343)
[12/21/2017 15:39:50] Status Message: Version 8.1.2 (8.1.2.2343)
[12/21/2017 15:39:50] Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
[12/21/2017 15:39:52] Starting node.exe
[12/21/2017 15:39:53] module.js:529
[12/21/2017 15:39:53]     throw err;
[12/21/2017 15:39:53]     ^
[12/21/2017 15:39:53] Error: Cannot find module 'fs-extra'
[12/21/2017 15:39:53]     at Function.Module._resolveFilename (module.js:527:15)
[12/21/2017 15:39:53]     at Function.Module._load (module.js:476:23)
[12/21/2017 15:39:53]     at Module.require (module.js:568:17)
[12/21/2017 15:39:53]     at require (internal/module.js:11:18)
[12/21/2017 15:39:53]     at Object.<anonymous> (C:\Users\asaito\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\dist\server\utils\logging.js:16:12)
[12/21/2017 15:39:53]     at Module._compile (module.js:624:30)
[12/21/2017 15:39:53]     at Object.Module._extensions..js (module.js:635:10)
[12/21/2017 15:39:53]     at Module.load (module.js:545:32)
[12/21/2017 15:39:53]     at tryModuleLoad (module.js:508:12)
[12/21/2017 15:39:53]     at Function.Module._load (module.js:500:3)
[12/21/2017 16:01:32] Studio Version 8.1.2 (8.1.2.2343)
[12/21/2017 16:01:32] Status Message: Version 8.1.2 (8.1.2.2343)
[12/21/2017 16:01:32] Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
[12/21/2017 16:01:33] Starting node.exe
[12/21/2017 16:01:34] module.js:529
[12/21/2017 16:01:34]     throw err;
[12/21/2017 16:01:34]     ^
[12/21/2017 16:01:34] Error: Cannot find module 'fs-extra'
[12/21/2017 16:01:34]     at Function.Module._resolveFilename (module.js:527:15)
[12/21/2017 16:01:34]     at Function.Module._load (module.js:476:23)
[12/21/2017 16:01:34]     at Module.require (module.js:568:17)
[12/21/2017 16:01:34]     at require (internal/module.js:11:18)
[12/21/2017 16:01:34]     at Object.<anonymous> (C:\Users\asaito\AppData\Roaming\ThingworxStudio\studio-download.vuforia.io\dist\server\utils\logging.js:16:12)
[12/21/2017 16:01:34]     at Module._compile (module.js:624:30)
[12/21/2017 16:01:34]     at Object.Module._extensions..js (module.js:635:10)
[12/21/2017 16:01:34]     at Module.load (module.js:545:32)
[12/21/2017 16:01:34]     at tryModuleLoad (module.js:508:12)
[12/21/2017 16:01:34]     at Function.Module._load (module.js:500:3)"
Somebody, help?
Thanks!
Anselmo.
