Login Problems with Vuforia View
drieder
Hello Everyone,
I am facing the following problem after scanning a Thingmark with the Vuforia View App on my Android Device:
The login window appears and asks for the user credentials as usual.
Now sometimes the experience loads but a second login window appears. If I cancel the window, the experience closes, if I log in again the window appears again. Sometimes I have to do this several times to finaly have access to the experience.
In other cases the the experience does not load at all and a second login window appears as well.
Anyone experiencing similar issues? Any help with this is appreciated very much.
Best Regards,
Dominik
3 REPLIES 3
pjahn
(To:drieder)
Do you have any external data (e.g. real time sensor data) that should be displayed in your experience?
Did you set public access to you experience in Studio (see "Configuration/Info/Access")?
drieder
(To:pjahn)
Yes I have real time sensor data that is displayed in my experience. I did not set the access to public since I would not be able to read the private sensor data.
dupatel
(To:drieder)
@drieder Do you see any error or details in Studio application or View app logs ?
Note: On Android, View app logs will be available at /Storage/Documents/Vuforia View/logfile.txt
-Durgesh
