Is it possible to make one word bold in a paragraph when using the Text Area or Text Input in Vuforia Studio
I have tried with HTML tag <b> and </b> but without success.
After some search over the web, standard text area doesn't accept HTML styling.
https://stackoverflow.com/questions/50286692/changing-a-small-amount-of-text-in-a-textarea-to-bold
In HTML, the best way to use styling in a text widget, is to use an external third party WYSIWYG text widget.
For example, this widget in Javascript :
I didn't check this approach for the moment.
Best regards,
Samuel
Hi Samuel,
Thank you very much for the information and for your help. I haven't had a chance to try your recommendation but will try and see if it works. Thank you again.
-Ada
