Hello there,
i had an error at the Picture Widget and could locate it at the file named twxPictureService.js.
There is a missing bracket that's it.
I hope the picture is enough for PTC to localize it.
Hi @AS_10340651 ,
thanks for reporting this issue in the Camera Widget of Vuforia Studio. so bracket is missing 3 times in lines 27,31,35 of the file twxPictureService.js. I reported this to R&D ticket VTS-1065 and hope this will be fixed for the next release. Currently you need to change the file manually to avoid this error.
BR
Hi @AS_10340651 ,
BR
