No environment in - View product is shown in a white background?
TG_10622756
How does one go about getting rid of showing a product in an environment?  Can the product be displayed in a white background?  Trying to replicate the CAD environment - product on a white background in Vuforia View?
Ok...for an update.  I resolved this by creating a large, shelled sphere around my product.  Initially, I thought that if I placed my product inside a shelled sphere, it would block the light and my product would be rendered black along with the inside of the shelled sphere.  My product 'floats' inside a large white sphere - an all white background - and I don't show the product sitting in my cluttered cubicle...ha!
Hi @TG_10622756 ,
I do not think that this is a real use case what is  intented for  Vuforia View AR usage- means to have some kind of Creo view. So possibly when the desired platform is a mobile then you can take the mobile version of creo view or onShape
Otherwise when you required some agumentation  you can add s some very large 3dimage Widget  for the background environment and set them with texture to have the desired background appearance.
When using a spatial target, you can trigger the service "freeze camera"
For rotation around other axis you can have a look at this thread: Possibility to change/set the spincenter (csys) of... - PTC Community
Using the new implemented 3D-Geometry data, you can choose the center of rotation : https://support.ptc.com/help/vuforia/studio/en/index.html#page/Studio_Help_Center%2Fcad_structure_api.html%23
Hello @TG_10622756 ,
It appears that @whity  provided an answers your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
When I read the conversation, it looks to me like you are trying to experience Virtual Reality.   Vuforia is targeted at Augmented Reality.
Thanks for using the PTC Community!
Pehowe
