You may not be able to login to the Community at the moment. We are working on a solution. We apologize for the inconvenience.
How does one go about getting rid of showing a product in an environment? Can the product be displayed in a white background? Trying to replicate the CAD environment - product on a white background in Vuforia View?
Hi @TG_10622756 ,
I do not think that this is a real use case what is intented for Vuforia View AR usage- means to have some kind of Creo view. So possibly when the desired platform is a mobile then you can take the mobile version of creo view or onShape
Otherwise when you required some agumentation you can add s some very large 3dimage Widget for the background environment and set them with texture to have the desired background appearance.
When using a spatial target, you can trigger the service "freeze camera"
For rotation around other axis you can have a look at this thread: Possibility to change/set the spincenter (csys) of... - PTC Community
Using the new implemented 3D-Geometry data, you can choose the center of rotation : https://support.ptc.com/help/vuforia/studio/en/index.html#page/Studio_Help_Center%2Fcad_structure_api.html%23
Ok...for an update. I resolved this by creating a large, shelled sphere around my product. Initially, I thought that if I placed my product inside a shelled sphere, it would block the light and my product would be rendered black along with the inside of the shelled sphere. My product 'floats' inside a large white sphere - an all white background - and I don't show the product sitting in my cluttered cubicle...ha!
