Not able to locate demo project mentioned in the post
vivekse
I saw this post by @RolandRaytchev
https://community.ptc.com/t5/Vuforia-Studio-and-Chalk-Tech/How-to-create-a-custom-button-pressable-on-HoloLens-device/ta-p/654984
But was not able to locate the demo project. Everytime I tried to import the files in studio it showed the message that file does not contain studio project.
Any idea where can I get that demo project.
Hi @vivekse ,
I tested again the project if it works and now I exported it "HoloLensTest3dButton-article.zip".
I think I forgot the attach the project it self. I am sorry. I attached the 3d Data and 3d Creo Parametric tool- so someone who has Creo Parametric 6.0 to customize the geometry - having button with customer text
This was a mistake I attached the Creo files 2 times and forgot to attach the project itself. I will correct the post :https://community.ptc.com/t5/Vuforia-Studio-and-Chalk-Tech/How-to-create-a-custom-button-pressable-o...
I am sorry for the incontinence. Please, let me know if you can load this project.
Because there is an issue to  upload the project I zipped it (the zip file was second zip) with password : PTC
First unzip the project-example.zip to HoloLensTest3dButton-article.zip which should be a valid project and could be imported into Studio
sdidier
(To:vivekse)
Hello Vivekse,
I have checked the files provided in this article of Roland.
It is the source files of 3D Models in Creo Parametric format and export in pvz file.
It is not an example Project who can be imported in Vuforia Studio.
Best regards,
Samuel
Hi @vivekse ,
vivekse
(To:RolandRaytchev)
Thank you @RolandRaytchev. Now I am able to open the project. Thank you...
