Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Not able to login into studio with Vuforia Dev Portal account after installing Vuforia studio
PS_10384051
6-Contributor
Hi All,
I recently installed Vuforia studio 9.5 on my laptop. I can run the exe but when I log in with my dev portal credentials it just has the loading screen. Please help
2 REPLIES 2
Please provide a screenshot of your issue.
PS_10384051
6-Contributor
(To:VladimirN)
Here is the log when I log in also:
[2022-08-23T13:13:25.413Z] Studio 9.5.0.5574
[2022-08-23T13:13:25.504Z] Status Message: Getting ready...
[2022-08-23T13:13:25.504Z] Starting node.exe
C:\Users\<USER>\Documents\VuforiaStudio/ssl-settings.json
[2022-08-23T13:13:34.542Z] info: [twx-studio:index] Studio Version 9.5.0.5574
[2022-08-23T13:13:34.815Z] info: [twx-studio:initializer] Node version: 14.17.6
[2022-08-23T13:13:34.818Z] info: [twx-studio:initializer] studio launched with the following arguments: {
_: [ 'C:\\Users\\<USER>\\OneDrive - <COMPANY>\\Documents' ],
'$0': 'C:\\Users\\<USER>\\AppData\\Roaming\\VuforiaStudio\\<COMPUTER_NAME>\\dist\\server\\index.js'
[2022-08-23T13:13:34.820Z] info: [twx-studio:initializer] studio dir: C:\Users\<USER>\Documents\VuforiaStudio , home dir: C:\Users\<USER>\Documents
[2022-08-23T13:13:41.383Z] info: [twx-studio:gitUtils] nodegit is not installed.
[2022-08-23T13:13:46.964Z] info: [twx-studio:ar-extension:upgrade] ar-extension version 9.5.0.5574 (1.59.2263)
[2022-08-23T13:13:51.822Z] info: [twx-studio:versionCheck] Version Check will use the update location: https://studio-download.vuforia.io/downloads/Studio.application
[2022-08-23T13:13:51.866Z] info: [twx-studio:index] Studio Ready: listening on localhost:3000
[2022-08-23T13:13:51.817Z] Status Message:
GET /api/projectTemplates 200 41.769 ms - 271
[2022-08-23T13:13:58.559Z] info: [twx-studio:pendingJobListenerService] Sending pending job notifications to all clients.
[2022-08-23T13:13:59.148Z] info: [twx-studio:pendingJobListenerService] Sending pending job notifications to all clients.
[2022-08-23T13:13:59.764Z] info: [twx-studio:versionCheck] version check complete 9.5.0.5574 9.5.0.5574 true
GET /api/version/check 304 172.239 ms - -
[2022-08-23T13:13:59.867Z] info: [twx-studio:versionCheck] version check complete 9.5.0.5574 9.5.0.5574 true
GET /api/version/check 304 101.096 ms - -
[2022-08-23T13:14:19.299Z] error: [twx-studio:index] uncaughtException Unexpected token < in JSON at position 2 SyntaxError: Unexpected token < in JSON at position 2
at JSON.parse (<anonymous>)
at Request._callback (C:\Users\<USER>\AppData\Roaming\VuforiaStudio\<COMPUTER_NAME>\dist\server\routes\auto-configure.js:68:28)
at Request.self.callback (C:\Users\<USER>\AppData\Roaming\VuforiaStudio\<COMPUTER_NAME>\node_modules\request\request.js:185:22)
at Request.emit (events.js:400:28)
at Request.emit (domain.js:470:12)
at Request.<anonymous> (C:\Users\<USER>\AppData\Roaming\VuforiaStudio\<COMPUTER_NAME>\node_modules\request\request.js:1154:10)
at IncomingMessage.<anonymous> (C:\Users\<USER>\AppData\Roaming\VuforiaStudio\<COMPUTER_NAME>\node_modules\request\request.js:1076:12)
at Object.onceWrapper (events.js:519:28)
at IncomingMessage.emit (events.js:412:35)
at IncomingMessage.emit (domain.js:470:12)
at endReadableNT (internal/streams/readable.js:1317:12)
at processTicksAndRejections (internal/process/task_queues.js:82:21) uncaughtExceptionVuforiaLogin.jpg
