Not able to publish experience in Vuforia Studio
Aditya1702
Hi Everyone,
Good Evening,
I am getting the below error when I am trying to publish experience in Vuforia Studio.
Error: DEPRECATION WARNING: The legacy JS API is deprecated and will be removed in Dart Sass 2.0.0.
Can anyone help me out.
Thanks in advance.
Aditya Gupta
Hi @PG_10144204 ,
Thanks for your reply.
We had raised a support case and the issue was solved.
Our application keys had expired. On increasing the expiration date of the application keys the issue was resolved.
PG_10144204
(To:Aditya1702)
Hi @Aditya1702 ,
  • Would you please share the version of Vuforia Studio you are using?
  • Does your project have any custom Javascript or CSS, any of those using deprecated API?
  • Can you share the Vuforia Studio logs and the Vuforia Experience Service logs to review?
  • I will also suggest opening a technical support ticket to investigate this issue.
Hi @PG_10144204 ,
