Dear Team,
I am working on project in which I want to show Thingworx Sensor Values in Vuforia Studio.
While working on that I am able to fetch things and data from Thingworx and able to see all data in Vuforia Studio Preview mode, but whenever I'm using Vuforia View from Ipad, Hololens & Android Tablet it's shows only labels or text.
I'm using latest version of Vuforia Studio: 9.0.1
Vuforia Experience Service(On Premises): 9.0.0
Thingworx Version: 8.5.0
Thanks!!
is your experience set to require authentication? (look under info > access)
you should see a prompt asking the user (in view) to log in. This would be a valid thingwor user id.
you may try the same id as you use to publish in Studio.
Thank you!!!
It's worked.
