I have received my login/password to access to ThingWorx Access Trial (it's correctly install, OK for use and to publish ThingWorx Studio for the three ThingMark)
but I have neither received (by Email) all ThingMarks (ZIP file)
I have this information by Email
but I have only 3 ThingMarks to download in Thingworx Studio Configuration (the one, second and third Third Thingmark in my serie)
can you explain and help me to obtain others ?
Herve
Hi HERVE BARTHELEMY,
Ok. If the issue is resolved; could you please close this Thread by marking Helpful and Correct answers (if any) so that other members know this Thread has a solution.
I will check internally regarding this and will get back to you.
Could you please confirm if you received a Welcome email with the Experience Server URL?
If No; does your Studio Configuration show the Experience Server URL?
Yes, I have received Welcome Email: March, 13, 2017
And I have an Experience Server URL and it works fine. (but only 3 Thingmarks that I have)
I have query related to Thingmark. I got bunch of thingmark when i got access to pilot program. I was able to manually add Thingmark details for each of my POCs but with latest release of Thingworx studio, i see only 3 thingmark in section - MyThingMarks. I am not sure how to add more in that list but i am able to use my other thingmark for experience.
Ravi
I have received an update internally. Trial period includes only 3 ThingMarks. More ThingMarks can be requested from R&D based on the requirement.
Could you please share your Business requirement, Experience Server Domain Id and number of ThingMarks required in a private message/email so that I can forward your request to R&D Team.
It's OK for me that in the Trial period, it's limited to only 3 ThingMarks.
I used my Private Email for this test, and it's OK for your answer.
I used another account, with my professional Email to tested.
Hervé
