I made an AR experience that streams a pvz from an azure blob storage container. Everything is working fine but the stream takes too much time despite the file being relatively small (96MB). Do you know how can I optimize said file in order to increment the streaming speed?
About PVZ optimization - "PVZ Optimizer Fail optimization": https://community.ptc.com/t5/Vuforia-Studio/PVZ-Optimizer-Fail-optimization/td-p/720585
