Dear Support Team,
I've noticed that when I create a sequence in Creo Illustrate and import it into Studio, some parts get lost or become transparent, when they should not be.
Is there a solution for this problem?
I cant send an example in this forum since it is a customer model. I can show it in a call.
Best wishes,
Alex
Dear @AlexK ,
Its a bug and the team is already working on it. Although one thing to try would be creating the animations again using the latest version of creo illustrate and importing it to studio, it has helped in few cases.
I'll update you once i am aware about the release date of studio version in which this bug would be fixed
BR,
Mohit
Dear @AlexK ,
BR,
Mohit
Hi Mohit,
I can't use Creo Illustrate 9, but i have the 8.1 Version. Would that work as well?
Best wishes,
Alex
