Since I have issues with the sequences in the HoloLens, I try to get a work around.
I have a Button, that invokes the function playStep(). The function starts with "modelItem-1". Then, the function moveAway() is invoked, which moves the modelItem and then makes it invisible. When the button is pressed again, it should automatically change to "modelItem-2" and start the same animation starting at its starting position, moving it up and making it invisible. Somehow I can’t get the script using a variable for the name “modelItem-1”. Can anyone help?
var modelItemCounter=1;
var timerId = -1;
var timingInterval = 30;
var angleIncrement = 45;
var ydelta = 0;
var speed = 0.01;
var modelItemVar;
$scope.app.playStep = function() {
$scope.modelItemVar= "modelItem-"+modelItemCounter;
console.log ("modelItem: "+ modelItemVar);
var zpos = $scope.view.wdg[modelItemVar]['z'];
$scope.moveAway();
$scope.moveAway = function()
if (timerId > -1)
clearInterval(timerId);
timerId = setInterval(function()
var stopPosition = $scope.view.wdg[modelItemVar]['z']+0.4;
$scope.app.params.zpos= $scope.view.wdg[modelItemVar]['z'];
$scope.$apply(function()
$scope.view.wdg[modelItemVar]['z']= $scope.view.wdg[modelItemVar]['z'] + speed;
console.log($scope.view.wdg[modelItemVar]['z']);
// $scope.app.params.zpos = $scope.app.params.zpos + speed;
, timingInterval);
setTimeout(function()
$scope.view.wdg[modelItemVar]['visible']=false;
modelItemCounter++;
, 2000);
I've made some small adjustments and used a 3D Label (instead of button) to trigger "playStep();" . It worked for me:
var modelItemCounter = 1; var timerId = -1; var timingInterval = 30; var angleIncrement = 45; var ydelta = 0; var speed = 0.01; var modelItemVar; $scope.playStep = function () { debugger; modelItemVar = "modelItem-" + modelItemCounter; console.log("modelItem: " + modelItemVar); var zpos = $scope.view.wdg[modelItemVar]['z']; $scope.moveAway(); } $scope.moveAway = function () { if (timerId > -1) { clearInterval(timerId); } timerId = setInterval(function () { var stopPosition = $scope.view.wdg[modelItemVar]['z'] + 0.4; var zpos = $scope.view.wdg[modelItemVar]['z']; $scope.app.params.zpos = $scope.view.wdg[modelItemVar]['z']; $scope.$apply(function () { $scope.view.wdg[modelItemVar]['z'] = $scope.view.wdg[modelItemVar]['z'] + speed; console.log($scope.view.wdg[modelItemVar]['z']); // $scope.app.params.zpos = $scope.app.params.zpos + speed; } ); } , timingInterval); setTimeout(function () { $scope.view.wdg[modelItemVar]['visible'] = false; clearInterval(timerId); modelItemCounter++; } , 2000); }
You've used $scope.modelItemVar in the start and referenced modelItemVar later. Either use modelItemVar everywhere (what I did)... Or use $scope.modelItemVar everywhere.
Hope it helps,
Ricardo Perdigao
Hope it helps,
Ricardo Perdigao
Thanks Ricardo, that worked! In the preview everything looks fine, in the Hololens, the parts won’t disappear. Seems like “$scope.view.wdg[modelItemVar]['visible'] = false;” doesn’t work. I’ll try other commands.
Regarding to the question about hidding of 3D modelItems in the sequnece. So for example this code will work on hololense :
setTimeout( function () {
var a1=var_arg1; //arguments to inline function
$scope.$apply(function () {$scope.view.wdg[a1]['forceHidden'] = true;});
$scope.$apply(function () {$scope.view.wdg[a1]['visible'] = false;});
$scope.$apply(function () {$scope.view.wdg[a1]['forceHidden'] = false;});
console.warn("started the timeoutfunction for "+ a1);
} , 3000);
I tested it and could verify that the 3D ModelItems are hidden after the 3 seconds.
-another approach will be to use the transparency (opacity property set it e.g. to 0 or in loop form 1-0 to have some effect like fade out)
So, regarding to your solution I have some points what I want to share.
For example we can have the case that you deleted and created modelitems so that they will be not continues in this case , may be, in this case you need something where you can use a list and specify there how to move your modelitems via different sets of speed , direction .etc.:
Here an example of code (I tested it on hololens and it worked fine) and should demonstrate how such solution could look like:
// $scope, $element, $attrs, $injector, $sce, $timeout, $http, $ionicPopup, and $ionicPopover services are available // $scope, $element, $attrs, $injector, $sce, $timeout, $http, $ionicPopup, and $ionicPopover services are available var modelItemCounter =0; var timerId = -1; var ydelta = 0; var number_objs=0; var model_size=0.5; var ray_call_interval_count=0; var animate_model_items = { "modelItem-6": { "csys-axis" : "z", "speed" : 0.01, "angleIncrement" : 45, "timingInterval" : 100 }, "modelItem-7": { "csys-axis" : "x", "speed" : 0.01, "angleIncrement" : 45, "timingInterval" : 20 }, "modelItem-8": { "csys-axis" : "y", "speed" : 0.01, "angleIncrement" : 45, "timingInterval" : 20 }, "modelItem-9": { "csys-axis" : "z", "speed" : 0.01, "angleIncrement" : 45, "timingInterval" : 60 }, "modelItem-10": { "csys-axis" : "z", "speed" : 0.01, "angleIncrement" : 45, "timingInterval" : 30 }, "modelItem-11": { "csys-axis" : "z", "speed" : 0.01, "angleIncrement" : 45, "timingInterval" : 150 }, "modelItem-12": { "csys-axis" : "y", "speed" : 0.01, "angleIncrement" : 45, "timingInterval" : 90 }, "modelItem-14": { "csys-axis" : "y", "speed" : 0.01, "angleIncrement" : 45, "timingInterval" : 90 }, "modelItem-15": { "csys-axis" : "y", "speed" : 0.01, "angleIncrement" : 45, "timingInterval" : 30 }, }; $scope.app.playStep = function () { // debugger; var m_items=Object.keys(animate_model_items); number_objs=Object.keys(animate_model_items).length; if(modelItemCounter >= number_objs) return; //exti { console.log(" number_obj="+ number_objs); console.log(" m_items["+modelItemCounter+"]="+ m_items[modelItemCounter]); $scope.moveAway(m_items[modelItemCounter],animate_model_items[m_items[modelItemCounter++]]); } }; //////////////////// $scope.moveAway = function (var_arg1,var_arg2) { // var_arg1 modelItemVar // var_arg2 modelItemObj ray_call_interval_count=0; if (timerId > -1) { clearInterval(timerId); console.log("ClearInterval");} console.log("var_arg2[\'timingInterval\']=" +var_arg2['timingInterval']); var original_position= $scope.view.wdg[var_arg1][var_arg2['csys-axis']]; timerId = setInterval( function ( modelItemVar,modelItemObj) { ++ray_call_interval_count; console.log("ray_call_interval_count="+ray_call_interval_count+"modelItemVar="+modelItemVar); var stopPosition = model_size/2; var current_pos = $scope.view.wdg[modelItemVar][modelItemObj['csys-axis']]; var movementDifference= current_pos -original_position; if(Math.abs(movementDifference) > Math.abs(stopPosition)) {clearInterval(timerId); console.warn("reached stop criteria!");} $scope.$apply((function (a1,a2) { console.log("apply a1="+a1); $scope.view.wdg[a1][a2['csys-axis']] = $scope.view.wdg[a1][a2['csys-axis']] + a2['speed']; console.log("set value for "+a1 +" to value" + $scope.view.wdg[a1][a2['csys-axis']]); // $scope.app.params.zpos = $scope.app.params.zpos + speed; })(modelItemVar,modelItemObj) //apply inline function );//applay funciton }, var_arg2['timingInterval'],var_arg1,var_arg2); //end of interval console.log ('timingInterval='+ var_arg2['timingInterval']); setTimeout( function () { var a1=var_arg1; //arguments to inline function $scope.$apply(function () {$scope.view.wdg[a1]['forceHidden'] = true;}); $scope.$apply(function () {$scope.view.wdg[a1]['visible'] = false;}); $scope.$apply(function () {$scope.view.wdg[a1]['forceHidden'] = false;}); clearInterval(timerId); console.warn("started the timeoutfunction for "+ a1); } , 3000); };
