Playing Animation in Thingworx viewer.
tingram
1-Newbie
Hello all,
     How do you relate a sequence to a toggle button with the capability of being played in Thingworx viewer, I have added a toggle button that is visible in Thingworx viewer however the sequence is not working.
Thank you in advance
-Timothy
4 REPLIES 4
mwassmann
(To:tingram)
Hej Timothy,
I guess you have created your sequence in Creo Illustrate, saved everything in a pvz file?
You just need to bind the toggle button action that you want to play the sequence with your model from the tree and select "play".
See this link (you can find it in the manual of Studio on the top right of the browser window under "..."):
PTC
Thank you
katte
1-Newbie
(To:tingram)
Adding to Martin's reply, please do follow the post ThingView app Release 1.10 - Unable to play the Animation
Giri
ankigupta
(To:tingram)
Hi Timothy Ingram​,
Please check following Blue Pump Quick Start Tutorial - YouTube which also explains how to play sequence with toggle button.
