How can i grab each (different) playing step on center of mobile screen.
i want to take all sequence in model in center of screen one by one
Can you provide additional details on your desired outcome? Are you already able to view the sequences within View on your mobile device?
Hello
Actually the steps are playing in my AR is on different locations of machine.
When i play it i cant see each step properly. i have to change location or rotate model for watch step.
i want each step automatically come front when playing
the sense of AR is overlaying the 3d with the reality on the position of the real part.
So you would most likely need to move your device towards the position that you are working on (with your sequence).
It is not a video.
Martin
