Is it possible to start Vuforia Studio as a service, not a program?
I've installed Studio Trial on a Windows 2016 Server and would like to not be dependent of a specific user to log in and start the program to get the web service running.
There are different user that can RDP the server and participate in building experiences.
@RagnarRoestad At the moment, Vuforia Studio is been offered as a program. If I understood your requirements correctly then I believe you can instead install the application locally on different individual machines/workstations. Then, multiple users can create experiences locally on there studio app, however, they can publish the projects with different names pointing to the same Vuforia Experience Service.
Or Is there a need for the different users to work on the same AR project simultaneously ??
-Durgesh
-Durgesh
Hi and thanks for your reply @dupatel
Since posting I have got a better understanding of Studio for design and the Experience Server for hosting the running experience. I also see from the installation guide that Studio is not supported for Windows 2016 Server.
/Ragnar
