After upgrade to 8.1.1 , does not operate the show/hide on canvas option for the popup widget.
is it just my problem?
Thnx
Giuseppe
Giuseppe Fiore: Could you please attach the snapshot describing the issue as do not see it locally.
Durgesh
In the previous version of Thingworx when I selected a popup and used hide on canvas,
the popup disappeared to work on the underlying widgets, now with the upgrade to 8.1.1 the
hide & show option does not work, the popup is always visible on the canvas.
THNX
Giuseppe
I have the exact same problem since the 8.1.1 update
Bob Wansink Ankit Gupta - It seems to be an issue with 8.1.1 and checking for a resolution.
-Durgesh
Giuseppe FioreAnkit GuptaBob Wansink
This issue has been noted by R&D team and has been fixed for the next release. As a possible workaround until the fix please use the drag and drop of the widgets in the tree structure in the left hand panel is one option.
-Durgesh
Thank you Durgesh Patel for the update. How soon can we expect the next release?
The workaround I use is to set the size of the popup to 1px for both width and height. This hides that popup and then while publishing I resize them back to the required size.
Ankit Gupta
