Problem with json file
leonardosella
Amethyst
Hi everyone,
I'm trying to load a json file that I upload into Vuforia Studio. The file contains a sequence of instruction that I have to print in a label.
The json file is like:
"steps":[
"Scollegare i cavi di collegamento indicati in giallo",
"svitare le quattro viti del basamento" ,
"Togliere il motore",
"Sostituire motore",
"Riposizionare motore nel basamento",
"Avvitare le quattro viti di sostegno",
"Collegare i cavi di alimentazione"
and the content of home.js like this one:
var myObj;
$scope.testJSON = function() {
$scope.asyncLoadScript("app/resources/Uploaded/repair_sequence.json").then(function(){
myObj = JSON.parse(myJSON);
console.log(myJSON)
function() { console.log("Oops, something went wrong"); });
$scope.updateLabel = function(){
$scope.setWidgetProp( "step-description", "text", "Description");
switch ($scope.app.view.RepairSequence.wdg["robot-arm-model"].currentStep) {
case 1:
text = myObj.steps[0];
$scope.setWidgetProp( "step-description", "text", text)
break;
case 2:
text = myObj.steps[1];
break;
case 3:
text = myObj.steps[2];
break;
case 4:
text = myObj.steps[3];
break;
case 5:
text = myObj.steps[4];
break;
case 6:
text = myObj.steps[5];
break;
case 7:
text = myObj.steps[6];
Once launched the preview nothing happen. Any suggestions?
Thank you
Tags (1)
10 REPLIES 10
Re: Problem with json file
Hello leonardosella,
You can try this function in order to read and load your JSON file:
// where jsonFile is './app/resources/Uploaded/repair_sequence.json'
readJson = function(jsonFile) {
  fetch(jsonFile).then(response => {
    return response.text();
  }).then(data => {
    myObj= JSON.parse(data);
  }).catch(err => {
    console.log ("Oops, something went wrong");
  I hope this was helpful.
Kind regards,
Lorena
Tags (1)
Hello @lgherman , thank you for your reply.
I tried the piece of code: when load the experience into console appear "Failed to load resource: the server responded with a status of 500 (Internal Server Error)". This kind of error exit every time i try to load the .json script.
Any suggestions? Thank you
// $scope, $element, $attrs, $injector, $sce, $timeout, $http, $ionicPopup, and $ionicPopover services are available
filePath = 'app/resources/Uploaded/repair_sequence.json';
finishedLoading = false;
angular.element(document).ready(function () {
    $scope.Init();
$scope.Init = function() {
    // Reading the file asynchronously
     $http.get(filePath)
      .success(function (data) {
        finishedLoading = true;
 		console.log(data.steps[0]);
    }).error(function (data, status, headers, config) {})
$scope.updateLabel = function() {
  if(finishedLoading == true)  {
   		// do your logic
Try the approach above. Also keep in mind that you must wait for the json to finish loading before reading from it. You can use a flag as I did in the example ( called finishedLoading )
Hi, the solution posted didn't work for my case. So, I choose to load a .txt file formatted with json-notation. Loading of the file takes place via xmlhttp as shown below.
  • var xmlhttp = new XMLHttpRequest();
    xmlhttp.onreadystatechange = function() {
    if (this.readyState == 4 && this.status == 200) {
    myObj = JSON.parse(this.responseText)
    console.log(myObj.sequenza_smontaggio)
    // logic
    xmlhttp.open("GET", "app/resources/Uploaded/istruzioni_montaggio_lingue.txt", true);
    xmlhttp.send();
Thanks for the help.
Hello @leonardosella, the solution proposed by @lgherman works correctly.
It may be that your .json file is badly formatted.
I share an example:
Kind regard.
Elias.
Betreff: Problem with json file
Hello Community.
It might be very helpful if someone can post a sample experience that contains a few steps and step description bind to a label. (especially for the non-coders)
Thanks in advance !
Cheers
Marco
(Presales) Senior Technical Consultant @ INNEO Solutions GmbH (Germany)
Hello everyone,
Here is a an example of how to read a JSON file and use the data to set the text of a label.
I hope this is useful.
Kind regards,
Lorena
Hi @lgherman
Thanks for sharing an example.
Elias
Thank you Lorena for this example!
I wanted to store players stats on a .JSON file. The problem is the file I made isn't appearing as an available resource in my file viewer in the editor. How do I get it to appear in my editor? can I use it even if it isn't shown as available?
edit: i've tried
Tags (1)
Join an
AR Working Group!
Topics available:
AR/VR for Data Optimization AR/VR for Security and Control AR/VR for Inspection
