Problems with playing sequences on HoloLens
Re: Problems with playing sequences on HoloLens
For me, the nice-to-have would be the inclusion of annotation and tools (as mentioned) that are created in Illustrate to populate in HoloLens when viewing sequences; seems the fix is only "half-fixed"?
Regardless, any progress is great.
Brian
Hi all,
tried Hololens today, one really simple sequence made in Illustrate 5.0 and in Hololens nothing played 😞
Bojan
1. check version of Studio and Vuforia view in your Hololens
2. We having same issues here (we can not figure out the reasons), but what help ist to creat a new projekt in Illustrate and do the animations again...than it works.....(sometimes )
Hi Raphael,
Studio is updating automatically (8.2.3) and on hololes View was updated 2 weeks ago (83.3.108.0)
I installed also Illustrate 4.2, preview works as it should, on hololes nothing.. 😕
Bojan
Hi Bojan,
here we have it 😉  Studio is not updating automatically.....
There is 8.3.3 available
Hi Raphael,
what? it did before.. what changed? Smiley Surprised Smiley Embarassed
And thank you, installed maunally new version and it is working now.. (some basic movement steps & color change made in Illustrate 4.2)
So now that 8.3.6 has been released, I've done some more testing on this and I've found the following updates for a model that has a sequence defined:
  1. setting display = false doesn't work
  2. setting forceHidden = true doesn't work
  3. setting opacity works - fixed!
  4. changing the sequence via JS works - fixed!
  5. changing the model source to a different PVZ works - fixed!
My workaround of using an application parameter to control opacity still works, so I don't have to redo that which is nice, but now I would just set the opacity of the widget directly.
I didn't expect that item 1 would  change as this is how it's always been, so it looks like it's only forceHidden that doesn't work on the HoloLens.
Sorry @RolandRaytchev, I haven't checked your issue of setting the sequence step via JS.  Hopefully this works now too.
