My organization blocks a lot of things on my system, so I want to share the different things I was going through to get ThingWorx Studio to work. We are working on Windows 10.
ThingWorx Studio doesn't give any clues, even with point 3 and 4 it says that the experience was published successfully, but nothing was shown after the ThingMark was scanned.
So hopefully this will help you to make publishing an experience a nice experience
E. Boer : Thank you for raising your concerns and your feedback will be helpful in improving our product. I will check on these to see if there are plans to improve or easy out publishing process. There are somethings implemented from the point of view to keep data secured and restricted however we actively look for feedback and suggestions for improvement.
I will post more details as soon as possible related to this on our future release plans and product road map. Once again thank you for sharing your experience and feedback !!
-Durgesh
Digging a bit deeper into the network troubles of ThingWorx Studio shows that it also wants an UDP connection to Google instead of the ThingWorx Experience server. And UDP-connections are blocked by our firewall. So why is this UDP-connection needed? Can it be changed into a TCP-connection?
