Re: Problems with playing sequences on HoloLens
bgračnar
<this is a new post based on a  quesiton to the old topic >
sequences are now working quite better.
Does anyone have a clue how to play 2 or more sequences on hololens?
Bojan
2 REPLIES 2
Hi @bgračnar
yes this is possible via javaScript. Example for playing of 2 sequneces
 $scope.app.sequence1 = function() {
     console.log("called $scope.sequence1");
     $scope.view.wdg['model-1']['sequence'] = 'app/resources/Uploaded/l-Creo 3D - fig_1.pvi';
     $timeout(
         //function() {angular.element(document.getElementById('model-1')).scope().playAll();}
         function() { $scope.$broadcast('app.view["Home"].wdg["model-1"].svc.playAll');
                      $scope.$applyAsync();
                   },1000);
     console.log("finished $scope.sequence1");
$scope.app.sequence2 = function() {
     console.log("called $scope.sequence2");
     $scope.view.wdg['model-1']['sequence'] = 'app/resources/Uploaded/l-Creo 3D - fig_2.pvi';
     //$timeout(function() {angular.element(document.getElementById('model-1')).scope().playAll();},1000);
      $timeout(
                    },1000);
   console.log("finished $scope.sequence2");
$scope.app.sequence = function() {
    $scope.app.sequence1();
    $scope.app.sequence2();
Ok the code above could work ok but there is another version which is more stable when you try  to play a sequence  on start / after model loaded event.
Here is another example which is more robust . There are  2 different functions for the calling of  play respectively  playAll .
$scope.app.loadsequence = function()
	{ $scope.setWidgetProp('model-1', 'sequence', "app/resources/Uploaded/l-Creo 3D - TestFigure1.pvi");
	  twx.app.fn.triggerWidgetService("model-1", 'play');
 $rootScope.$on('modelLoaded', function()
               {$scope.app.loadsequence();
                console.warn("$scope.app.loadsequence() executed");
 				$timeout( function() {
                          console.warn("app.loadsequence() executed");
                                     }, 1000);
$scope.app.loadsequence1 = function()
	{ $scope.setWidgetProp('model-1', 'sequence', "app/resources/Uploaded/l-Creo 3D - SecondTestFigure.pvi");
	  twx.app.fn.triggerWidgetService("model-1", 'playAll');
I think it is possible to execute more than one sequence consecutively  in particular order. I could not remember if this was working but if there is a problem we can try to call the next sequence from the step-completed event of the last step (ok this requires some additional checks) but we need to consider this only if we face a problem when calling several sequences consecutively
Roland,
thank you wery much for answer!
I see that there is option to play one sequence after another.
I guess there is no option to selecting sequences (for service procedures)?
Bojan
