<this is a new post based on a quesiton to the old topic >
sequences are now working quite better.
Does anyone have a clue how to play 2 or more sequences on hololens?
Bojan
Hi @bgračnar
yes this is possible via javaScript. Example for playing of 2 sequneces
*********/ $scope.app.sequence1 = function() { console.log("called $scope.sequence1"); $scope.view.wdg['model-1']['sequence'] = 'app/resources/Uploaded/l-Creo 3D - fig_1.pvi'; $timeout( ////////////////////////////////////////// //function() {angular.element(document.getElementById('model-1')).scope().playAll();} ///////////////////////////////////////// function() { $scope.$broadcast('app.view["Home"].wdg["model-1"].svc.playAll'); $scope.$applyAsync(); ////////////////////////////////////////// },1000); console.log("finished $scope.sequence1"); } $scope.app.sequence2 = function() { console.log("called $scope.sequence2"); $scope.view.wdg['model-1']['sequence'] = 'app/resources/Uploaded/l-Creo 3D - fig_2.pvi'; //$timeout(function() {angular.element(document.getElementById('model-1')).scope().playAll();},1000); $timeout( function() { $scope.$broadcast('app.view["Home"].wdg["model-1"].svc.playAll'); $scope.$applyAsync(); ////////////////////////////////////////// },1000); console.log("finished $scope.sequence2"); } $scope.app.sequence = function() { $scope.app.sequence1(); $scope.app.sequence2(); }
Ok the code above could work ok but there is another version which is more stable when you try to play a sequence on start / after model loaded event.
Here is another example which is more robust . There are 2 different functions for the calling of play respectively playAll .
$scope.app.loadsequence = function() { $scope.setWidgetProp('model-1', 'sequence', "app/resources/Uploaded/l-Creo 3D - TestFigure1.pvi"); twx.app.fn.triggerWidgetService("model-1", 'play'); }; /////// $rootScope.$on('modelLoaded', function() {$scope.app.loadsequence(); console.warn("$scope.app.loadsequence() executed"); $timeout( function() { $scope.app.loadsequence(); console.warn("app.loadsequence() executed"); $scope.$applyAsync(); }, 1000); }); $scope.app.loadsequence1 = function() { $scope.setWidgetProp('model-1', 'sequence', "app/resources/Uploaded/l-Creo 3D - SecondTestFigure.pvi"); twx.app.fn.triggerWidgetService("model-1", 'playAll'); };
I think it is possible to execute more than one sequence consecutively in particular order. I could not remember if this was working but if there is a problem we can try to call the next sequence from the step-completed event of the last step (ok this requires some additional checks) but we need to consider this only if we face a problem when calling several sequences consecutively
Roland,
thank you wery much for answer!
I see that there is option to play one sequence after another.
I guess there is no option to selecting sequences (for service procedures)?
Bojan
