I setup windows device portal, connected to my hololens and tried to record including hologram . .recording works but cannot see the hologram in the TW View experience .. other menus on the hololens appear no problem during the recording.
Hej Francois,
easy: you need to use the voice control command within Thingworx View: "Hej view, enable recording".
Then the live stream works.
Martin
Hej Francois,
Martin
thanks .. was just pushing recording on the device portal
