Scan QR Code using Scan Widget & Text Input [3D-Eyeware]
NA_nur
11-Garnet
I have trouble in scanning small QR Code when using 3D-Eyeware (Hololens II). The QR Code size is 0.5cm2.
If the QR Code cannot be scanned I would like to have another option which user input text or accept voice as input to text. But I cannot see any function for that kind of input.
Any kind of idea would really appreciated as this scanning function is very crucial in my project.
Many thanks.
Hi @dsgnrClarK ,
Appreciate your reply and thank you for the reference.
Actually, I just realize the label that need to be scanned is data matrix barcode which is not supported on Hololens device.
I found ZXing library (as link below) that support data matrix scanning.
https://opensource.google/projects/zxing
How can I integrate the library inside Vuforia Studio scanning to use ZXing image processing to get the data matrix barcode value?
Thank you.
Suraj_Patil
(To:NA_nur)
Does anyone has answer for this ?
i m also looking for the same solution.
Topics available:
AR/VR for Data Optimization AR/VR for Security and Control AR/VR for Inspection
