Hello, I've prepared a section animation step in a sequence from creo illustrate.
when importing the pvz into vuforia studio the sectioning animation is not shown.
Why? How to solve this issue?
Thank you
Currently sectioning sequence is not supported
You could achieve this functionality using js. Have a look at solution 3.) at this post:
Section view or Clipping of model display in Vu... - PTC Community
Instead of a slider you can use a loop that lets the variable slicexCur add up.
