I am using the select widget to select the sequence to play. I would like to have this list default to a specific sequence. Is this possible?
Hi @Wayne_Beck ,
One of the ways to set a default selection for select input widget is as shown below:
Hope this helps!
Hi @Wayne_Beck ,
Hope this helps!
This helped but now I face a few issues. I would prefer my list not have "l-Creo 3D - Installation Orientation.pvi" in the drop down and just be "Installation Orientation". Second my play button no longer works to start the sequence. Any help on this would be great.
Hi @Wayne_Beck,
Thank you again I now have the list showing correctly. But I am still unable to get my sequences to play with the button.
I now have some of the sequences working.
