Per this post -
How do one extract the .pvi files from the .pvz file? Ive seen some comments on copying and making it a zip file, and extract from there.. but I don't get that working? could you explain?
thanks
Hi @lundha ,
One way to extract the pvi file is as follows:
Hope this helps!
Hi @lundha ,
Hope this helps!
