Hey everybody,
i am just working with Thingworx Trial since two weeks now.
All in all it is working pretty good and the tutorials are awesome! But i have two rather big problems, where i am struggling with for quite a few days:
I wanted to show the description of each single step. My intention was to use the Annotation Boxes in Creo, but as i understood in this community forum, this is not working. I then wanted to try this workaround: Display sequence step names from Creo Illustrate The problem here is that it it only show the name of the Label in the App. I don't really understand this sentence: Now you only need to provide the correct initial value in the Label widget text property and add control widgets (Buttons, Playback) to drive your animation and you're done. Could you help me here what this means? What is my initial value of a sequence step?
Thank you so much for your help in advance!
Best regards from Germany
Lorenz
Check your sequence in Illustrate. It execute each movement according a percentage. So the complete movement is 100%. You need to set each movement (item) be a certain percentage. Adjust the percentage for the amount of time you want each step to use out of the total time of the sequence.
As you see here my step run for 3.5 seconds and I have each movement take 10% of the 3.5 seconds to run. Hope this helps.
Sandra
