Hello, I would like to know if there is a way to show annotations (such as dimensions) in an AR experience made with Vuforia Studio. For example, I save a PVZ file from creo view and import said PVZ file into the experience and, along with the model, the dimensions related to that pvz are shown too.
Thanks in advance
I found a solution: I exported a pvz from creo Illustrate with sequences showing each view with dimensions and uploaded this file in my AR experience in Vuforia Studio
Similar question - "EDM dimension annotations in Vuforia": https://community.ptc.com/t5/Vuforia-Studio/EDM-dimension-annotations-in-Vuforia/td-p/680607
Yes, I read that article but what has been said there isn't working and, since the article is more than 4 years old, I wondered if there was another way to show the annotations.
