[localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war
[localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
I resolved it by setting Environment 'Path' variable value by <Installed Drive>Apache Software Foundation\Tomcat 8.5\webapps\Thingworx\WEB-INF\extensions
And start tomcat from -> Apache Software Foundation\Tomcat 8.5\bin\startup.bat
Guangyan Guo -
What is the operating system you are installing it on ? And also are these complete logs that you have attached ?
Thanks ,
Mukul Narang
Install Thingworx 8 on win10,This is the full log for Tomcat
14-Sep-2017 15:07:11.395 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.0.44
14-Sep-2017 15:07:11.399 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: May 10 2017 17:21:09 UTC
14-Sep-2017 15:07:11.399 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.0.44.0
14-Sep-2017 15:07:11.399 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 10
14-Sep-2017 15:07:11.439 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 10.0
14-Sep-2017 15:07:11.439 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
14-Sep-2017 15:07:11.439 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Program Files\Java\jre1.8.0_92
14-Sep-2017 15:07:11.439 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_92-b14
14-Sep-2017 15:07:11.439 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
14-Sep-2017 15:07:11.439 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Program Files\Apache Software Foundation\Tomcat 8.0
14-Sep-2017 15:07:11.440 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Program Files\Apache Software Foundation\Tomcat 8.0
14-Sep-2017 15:07:11.440 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 8.0
14-Sep-2017 15:07:11.441 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 8.0
14-Sep-2017 15:07:11.441 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=C:\Program Files\Apache Software Foundation\Tomcat 8.0\endorsed
14-Sep-2017 15:07:11.441 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 8.0\temp
14-Sep-2017 15:07:11.441 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
14-Sep-2017 15:07:11.441 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 8.0\conf\logging.properties
14-Sep-2017 15:07:11.441 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dserver -Dd64
14-Sep-2017 15:07:11.442 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseG1GC
14-Sep-2017 15:07:11.442 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dfile.encoding=UTF-8
14-Sep-2017 15:07:11.442 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.library.path=C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx\WEBINF\extensions
14-Sep-2017 15:07:11.442 信息 [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit
14-Sep-2017 15:07:11.442 信息 [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx\WEBINF\extensions
14-Sep-2017 15:07:11.625 信息 [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
14-Sep-2017 15:07:11.772 信息 [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
14-Sep-2017 15:07:11.775 信息 [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]
14-Sep-2017 15:07:11.779 信息 [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
14-Sep-2017 15:07:11.779 信息 [main] org.apache.catalina.startup.Catalina.load Initialization processed in 1062 ms
14-Sep-2017 15:07:11.818 信息 [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
14-Sep-2017 15:07:11.819 信息 [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.44
14-Sep-2017 15:07:11.849 信息 [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war
14-Sep-2017 15:07:46.489 信息 [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger
Guangyan Guo - I just noticed , -Djava.library.path=C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx\WEBINF\extensions .You have added this to your tomcat configuration Java tab ,but WEBINF is WEB-INF in the folder structure i assume .Can you please check this and change this to -Djava.library.path=C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx\WEB-INF\extensions and try restart the tomcat again .
Mukul Narang
