Hi everyone,
i just downloaded Creo Illustrate and got a e-mail with my licence pack (.dat-file).
I saved this .dat-file into: C:\ProgramData\PTC\Licensing\
After starting Creo Illustrate i get the message: "Cannot find licence file", but the file is in this folder.
What am I doing wrong?
Thank you for your help!
Thank you for your help, really appreciate it.
I was not able to read the article (see attached picture) and then i tried some things on my own:
reinstalling the software (did not worked)
trying to use the free student version (same license issue)
reinstalling creo illustrate 6.0 and suddenly it worked? I don't know why but on thing that could have been the problem was, that in the field "License server" you need to write in not only the path of the file: C:\ProgramData\PTC\Licensing
I think the correct way is to also add the license file into the field "License server":
C:\ProgramData\PTC\Licensing\sw_license_email_1234567.dat
I think this is a license file which could be a locked license file (where there is no flexnet server requidred) or this is a flexNet server licens file which should be used for the installing of the flexnet server. Here some references:
Where is suggested:
Delete the content of %appdata%/ptc/Illustrate folder
Enter the correct path to the license file in the License Server field
NOTE: Article - CS49606 provides information on configuring Creo Illustrate license
How to fill in the License Information of Creo View and Creo Illustrate Startup dialog box
If you can not see the PTC article (to be albe to see the contetnt of the article you need a user accont to the ptc database) , you can let me know to share it here the relevant info form the first article:
Resolution
Create an Environment Variable PTC_D_LICENSE_FILE with value pointing to:
For node locked license file - Location of node locked license file
For floating license file - <7788@SERVER_NAME>
Refer article CS257475 to know how to set environment variable PTC_D_LICENSE_FILE.
Means in your case - here you dont have a server but you have a locked license file.
The correct solution is to create a variable PTC_D_LICENSE_FILE and to set it to the complete path of the license file. So far I see the installation used by default the variable PTC_D_LICENSE_FILE
