Hello, everyone,
is there a way to switch between the different views in a project without using the navigation menu? Possibly by clicking on a text label.
In my case I want to switch between the views: "Home", "ELT UV 13" and "ZLT UV 12".
Has anyone ever implemented something like this before and can tell me how to do it?
I would also like to try to use the barcode scanner to switch to a specific view.
It would be nice if you could help me further.
Best regards
this article should help you. Look at the end of it.
Hi Sebben,
Thank you for your quick and helpful answer. You were able to help me with the post.
Have a nice weekend.
