Does experience always have to tie to a Thingmarks? When I run ThingView, is there alternative to scanning ThingMarks to run the experience?
No. You can select other options. One of them that you don't associate your experience with any ThingMark. Then the Experience will be listed in your bookmarks in ThingWorx View. For that, you have to specifiy the URL of the Experience Server in the settings of ThingWorx View.
Also for the Target you have now the choice e.g. to use Spatial Tracking. or CAD Model based Targets.
Also for the Target you have now the choice e.g. to use Spartial Tracking. or CAD Model based Targets.
