ThingWorx Composer not showing any entities
dsengupta-21
2-Explorer
I am getting the above error while starting the composer.
Can anyone please check internally?
Thanks & Regards,
Dipika Sengupta
9 REPLIES 9
AnnaAn
(To:dsengupta-21)
Dipika Sengupta​,
Could you make sure if your user session is time out? Try to log out and log in again see if the issue persists?
Br,
Anna
Hi Anna An​,
I have tried logging out and logging in several times. But the same problem persists.
Dipika
Hi Dipika Sengupta​,
Is this a PTC hosted instance (Trial or Commercial) or local instance?
If it is a PTC hosted instance (Commercial); I will suggest you to open a case with PTC for this issue.
Ankit Gupta
Hi Ankit,
This is the trial instance only.
Dipika
AnnaAn
(To:dsengupta-21)
If this is the hosted trial instance, try to login developer.thingworx.com and check your trial server status:
Try to Start Foundation Server and see if issue is gone.
Br,
Anna
Hi Anna An
This not the account I am using. my id is dipika.sengupta@in.abb.com.
This is the page I am getting.
Dipika
I will send a mail internally to concerned Team to check.
ankigupta
(To:AnnaAn)
Hi Anna An​,
This is related to ThingWorx connected with ThingWorx Experience Service.
AnnaAn
(To:ankigupta)
Ankit Gupta​,
Wow I just noticed that from the snapshot.
Thanks for letting me know.
Br,
Anna
