I don't know if it's a problem or I am doing something wrong. I create some projects with 3D models but when I scan my thingmark he recognizes the project but don't show anything.
I already tried just using some 3D gauges but don't work as well.
Best regards
Gonçalo Machado : Could you please confirm if project was published successfully. Also, do you see any errors in Studio application log?
Is there any message on View app ?
-Durgesh
No, nothing.
The top bar shows the project name and that's it.
Gonçalo Machado: Request you to please attach the Studio application log to reviewing the issue further.
This?
From the subject, "when I scan my thingmark he recognizes the project " just curious, how did you notice that the View app recognizes the project? Is that something like, the View app displays the name of the project or show a pop-up to select the project?
As your Studio logs reports no error, I guess this might be due to network security (within your device) i.e., the device is unable to reach/access the ES url. To validate network issue, can you please try accessing your ES url from the device browser??
Just an FYI, if you have 'auto-configured' portal login in Studio, you should find the ES-url under Project configuration -> info section -> Experience Service field.
Yes it shows a pop-up to select the project and then the name fixes at the top bar.
I think that I can access my ES url, the result was the same with the pc but in different networks.
After some experiments I could see a 3D image in a project. The image was almost behind the camera. Maybe the problem is that I have my models bad positioned.
How can I change that?
