Thingworx Experience Service local
BSUN_RO
Hi, I have running a local instance of Thingworx Composer and Experience Service on a computer and Vuforia on another computer on local network. In Vuforia I set Experience URL: http://localip:8080
I started the Experience Service with "--allowsc --nossl" options. I also set the appkey in "proxies.0.appkey" and I set the permission for executing services for the specified user. However, I get the error in Vuforia "Error connecting to the ThingWorx server". How to solve this ? Thankyou very much
@BSUN_RO ,
1. Can you access to ThingWorx composer via the URL http://localhost:8015/Thingworx?
2. If your ES listening port is 8080, can you get the OK response via URL:
  http://localhost:8080/ExperienceService/ping
3. If you use Administrator account to vaild the URL http://localhost:8080/ via Configuration> Info > Experience Service > Valid in the Studio Project, can you pass the validation?
4. You may upload the configuration.json under <Vuforia-ES> for check
tmccombie
(To:BSUN_RO)
The default port for the Experience Service is 2019. 8080 is the default for Tomcat/TWX. Can you confirm which URL you have entered into Studio?
BSUN_RO
(To:tmccombie)
I set the experience url in Studio now to http://localip:2019 and I get the same error. I started the experience service on the other server with this configurations: authentication -> "baseUrl": "http://localhost:8015", proxies -> "target": "http://localhost:8015/Thingworx", websocketProxies-> "target": "ws://localhost:8015" and is listening on port 8080.
@BSUN_RO ,
BSUN_RO
(To:Jimwang)
This helped me fix it. Thankyou.
