Thingworx studio authentication issue
Tarun
I have installed thingworx studio trial version (30 days trial period). When i am trying to publish the project or trying to preview it, it's asking for a "Authentication Required" pop-up. After giving the credentials, it is asking for the same authentication again and again. Attaching the screenshot on the same. Also i am using the same credentials to login to my studio account and it is taking correctly over there.
same authentication is being asked again and again when i am trying to access the thingworx cloud Iot platform using the experience server url as:
ES: https://icbeewyj.studio-trial.thingworx.io
Thingworx iot platform: https://icbeewyj.studio-trial.thingworx.io:8443/Thingworx/Composer/index.html
Is there any problem with the installation. I am trying all these steps using my public network( phone as well as my home wifi router).
Please help me.
Tarun
tmccombie
(To:Tarun)
Hi Tarun, the credentials you use for logging into the portal should work for publishing. Can you please share your Studio log.
Tarun
(To:tmccombie)
Adding the log file
Tarun
I am having the same issue here. Did you manage to solve the issue? I have also attached the log files in case this will help in any way.
